Display the RSTP Role
Perform the following procedure to display the RSTP information.
  1. To enter User EXEC mode, log on to the switch.
  2. Display the RSTP role:
    show spanning-tree rstp port role [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Switch:1> show spanning-tree rstp port role 1/3
                           RSTP Port Roles and States
Port-Index  Port-Role    Port-State   PortSTPStatus  PortOperStatus
1/3        Designated   Forwarding   Enabled        Enabled
Variable definitions
Use the data in the following table to use optional parameters with the show spanning-tree rstp port role command.
Variable
Value
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
